PeriFerry is an organisation founded in 2017 that helps transgender individuals with employment and skilling opportunitie, in addition to creating LGBTQIA+ friendly workplaces.
As a part of our NPO Support, FOSS United is helping PeriFerry onboarding new candidates & trainees who reached out to them for jobs.
Summary of call on 2nd Feb (10:30AM-12:00PM):
Agenda: To workaround on the issue where table multiselect field type cause creation of multiple rows (rows equals to the number of languages selected in the field).
Present: @nikochiko , Vishal
Solution: @Anand suggested that we should concatenate all the languages and assign it to a new field (read only) and use that field to generate report. Kaustubh wrote a server script to do this.
Status: Issue solved
Problem faced:
- Some mandatory fields were blank earlier
- Some options in the
selectfield types were changed which cause error while saving the records.
